I am attempting to run the node.js HelloWorld example as detailed in http://cesiumjs.org/2013/04/12/Cesium-up-and-running/ (which btw is awesome - what a simple way to run your own webserver without a lot of technical know how and fuse).
I am getting cross domain exceptions so I am trying to setup a proxy as defined in http://cesiumjs.org/2013/01/04/Cesium-Imagery-Layers-Tutorial/. The linked Proxy is a java application with no running instructions. How can I run the java application and the node application on the same port at the same time? Do you have a node.js proxy? Would it be possible to include the proxy in the provided server.js?
