ssteph
1
I’ve added a property to an entity with viewer.selectedEntity.properties.addEntity("myPropertyName", true) but how do I
- choose this particular property by name when using the getValue() method?
- update the value of that specific property later?
I can’t find any code examples of this. And the docs aren’t clear to me on it either.
ssteph
2
Any time I try to access entity.properties it says that properties is undefined. So it will not let me add a property using the method there.
If I use entity.addProperty("myPropertyName") I can’t figure out how to access it, either.
dzung
3
You can access the property by the property name. For example:
var blueEllipsoid = viewer.entities.add({
name: "Blue ellipsoid",
position: Cesium.Cartesian3.fromDegrees(-114.0, 40.0, 300000.0),
ellipsoid: {
radii: new Cesium.Cartesian3(200000.0, 200000.0, 300000.0),
material: Cesium.Color.BLUE,
blueEllipsoid.addProperty('age');
blueEllipsoid.age = 11;
console.log(blueEllipsoid.age);
The code above will print out 11 as the value for blueEllipsoid's age.
