In cesium development, add a large cone, and how to set it so that the cone appears to “grow out” from the ground rather than hang in the air like a spaceship. I want to create a signal range for the satellite. thank you!
const redCone = viewer.entities.add({
position: Cesium.Cartesian3.fromDegrees(-105.0, 40.0, 200000.0),
cylinder: {
length: 400000.0,
topRadius: 0.0,
bottomRadius: 2000000.0,
material: Cesium.Color.RED,
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND,
You probably don’t want the heightReference: CLAMP_TO_GROUND
part here. This basically causes the bottom of the cone to always touch the ground, regardless of its position (height) and length.
Here is a sandcastle that shows the three aspects that affect the appearance of the cone:
- The “height” is the z-component of the
position
of the cone entity
- The “length” is the overall length of the cone
- The “clamp” checkbox allows enabling/disabling the
CLAMP_TO_GROUND
behavior
When clamping is disabled, then…
- you can move the cone up and down with the “height” slider
- you can change the length of the cone with the “length” slider
When clamping is enabled, then
- you can NOT move the cone up and down with the “height” slider. It will always stick to the ground.
An aside: You may notice that when you modify the “length”, then the cone stretches/shrinks about its center. If you want the tip of the cone to be fixed, then the length of the cone has to be taken into account when defining the z-component of the position. This can be achieved by defining the position
as
position: new Cesium.CallbackProperty(() => {
const z = Number(viewModel.height) - 0.5 * Number(viewModel.length);
return Cesium.Cartesian3.fromDegrees(
-105.0,
40.0,
z
}, false),
Then, when you modify the length, the tip of the cone will stay fixed.
EDIT: It might be that all that you have been looking for was the
viewer.scene.globe.depthTestAgainstTerrain = true;
setting.
But regardless of that, I hope that the sandcastle shows how to achieve the effect of the cone to “grow out” of the ground:
Thank you for taking the time to reply. Your answers and sandbox examples are very helpful to me.
Due to the height limitation given by the orbital data, I cannot adjust the cone height at will, but I can calculate the required orbital height according to the depth inserted into the surface. This requires some detours, but it is not a problem.
Thanks again for your reply.
