The wall drawn through WallGeometry has no outline,The wall drawn through WallOutlineGeometry has no surface.How to add a outline to WallGeometry.
var AODLocs = ;
AODLocs.push(115.33);
AODLocs.push(39.33);
AODLocs.push(115.55);
AODLocs.push(39.55);
AODLocs.push(115.66);
AODLocs.push(115.88);
AODLocs.push(115.83);
AODLocs.push(115.92);
AODLocs.push(115.96);
AODLocs.push(116.22);
AODLocs.push(116.66);
AODLocs.push(39.57);
AODLocs.push(116.88);
AODLocs.push(39.59);
AODLocs.push(116.99);
AODLocs.push(39.62);
AODLocs.push(117.11);
AODLocs.push(39.66);
AODLocs.push(117.33);
var instances = ;
for (var i = 0; i < AODLocs.length - 2; i = i + 2) {
instances.push(new Cesium.GeometryInstance({
geometry: new Cesium.WallGeometry({
positions: Cesium.Cartesian3.fromDegreesArrayHeights([
AODLocs[i], AODLocs[i + 1], 50000,
AODLocs[i + 2], AODLocs[i + 3], 50000
outline: true,
outlineColor: Cesium.Color.RED,
outlineWidth: 10,
vertexFormat: Cesium.VertexFormat.POSITION_AND_COLOR,
attributes: {
color: Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.fromRandom().withAlpha(0.6)),
outlineColor: Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.RED),
outline: new Cesium.GeometryInstanceAttribute({
componentDatatype: Cesium.ComponentDatatype.UNSIGNED_BYTE,
componentsPerAttribute: 1,
normalize: true,
value: [1.0]
viewer.scene.primitives.add(new Cesium.Primitive({
geometryInstances: instances,
appearance: new Cesium.PerInstanceColorAppearance({
flat: true,
translucent: true
