I am representing an object using a combination of a polyline and a billboard entity, where the billboard acts as a label positioned on the line.
Requirement
My requirement is:
The label (billboard) must be rendered in front of the polyline
The entire object (polyline + label) must be rendered on top of all other objects in the scene
Current Implementation
To disable depth testing, I am currently using the following settings:
- For the polyline primitive:
renderState: {
depthTest: {
enable: false
- For the billboard entity:
disableDepthTestDistance: Number.POSITIVE_INFINITY
Problem
With this implementation:
The polyline is rendered on top as expected
However, the billboard (label) is rendered behind the polyline
As a result, I cannot satisfy the requirement that the label should appear in front of the polyline, while also keeping the entire object always rendered on top of other scene elements.
Question
Is there a way to render a polyline and its billboard together as a single object, such that:
the billboard is always rendered in front of the polyline, and
the whole object is always rendered on top of all other entities?
Alternatively, is there a more appropriate approach (for example, using different primitives or render order control) to achieve this behavior?
Any guidance would be appreciated.
