I have rendered a simple custom primitive (a triangle). Now I want to animate the triangle.
Firstly I try to change the vertex data of the triangle to see if the triangle will move to the new location.
But it duplicates the triangle, the old triangle doesn’t disappear. As shown below.
Here is my code in Sandcastle:
var TrianglePrimitive = /** @class */ (function () {
function TrianglePrimitive(options) {
this._dirty = true;
this._positions = options.positions;
this._vertices = ;
this._colors = ;
this._show = options.show || true;
this._material = Cesium.Material.fromType(Cesium.Material.ColorType);
this._modelMatrix = Cesium.Matrix4.clone(Cesium.Matrix4.IDENTITY);
this._drawCommand = new Cesium.DrawCommand({ owner: this });
Object.defineProperty(TrianglePrimitive.prototype, "positions", {
get: function () {
return this._positions;
set: function (value) {
if (this._positions !== value) {
this._positions = value;
this._dirty = true;
enumerable: true,
configurable: true
TrianglePrimitive.prototype.update = function (frameState) {
if (!this._show) {
return;
var context = frameState.context;
this.vertexArray = (this._dirty || !this.vertexArray) ? this.createVertexArray(context) : this.vertexArray;
this.setupShaderProgram(context);
this.setupRenderState();
var passes = frameState.passes;
if(passes.render){
this.setupDrawCommand();
frameState.commandList.push(this._drawCommand);
TrianglePrimitive.prototype.sceneModeChanged = function (mode) {
return this._lastMode !== mode;
TrianglePrimitive.prototype.createVertexArray = function (context) {
this._dirty = false;
for(var i=0;i<this._positions.length;i++){
var position = this._positions[i];
this._vertices.push(position.x);
this._vertices.push(position.y);
this._vertices.push(position.z);
this._colors.push(Math.random());
var positionVertexBuffer = Cesium.Buffer.createVertexBuffer({
context: context,
typedArray: new Float32Array(this._vertices),
usage: Cesium.BufferUsage.STATIC_DRAW
var colorVertexBuffer = Cesium.Buffer.createVertexBuffer({
context: context,
typedArray: new Float32Array(this._colors),
var attributes = [
index: 0,
enabled: true,
vertexBuffer: positionVertexBuffer,
componentsPerAttribute: 3,
componentDatatype: Cesium.ComponentDatatype.FLOAT,
normalize: false,
offsetInBytes: 0,
strideInBytes: 0
index: 1,
enabled: true,
vertexBuffer: colorVertexBuffer,
normalize: false,
offsetInBytes: 0,
strideInBytes: 0
var vertexArray = new Cesium.VertexArray({
context: context,
attributes: attributes,
indexBuffer: this.createIndexBuffer(context)
return vertexArray;
TrianglePrimitive.prototype.setupShaderProgram = function (context) {
this._shaderProgram = this._shaderProgram || Cesium.ShaderProgram.replaceCache({
context: context,
shaderProgram: this._shaderProgram,
vertexShaderSource: "attribute vec3 position;\n"+
"attribute vec3 color;\n"+
"varying vec4 v_color;\n\n"+
"void main() {\n"+
"gl_Position = czm_modelViewProjection * vec4(position, 1.0);\n"+
"v_color = vec4(color,1.0);\n"+
fragmentShaderSource: "varying vec4 v_color;\n"+
"void main(){\n"+
"gl_FragColor = v_color;\n"+
TrianglePrimitive.prototype.setupRenderState = function () {
this._renderState = Cesium.RenderState.fromCache({
cull: {
enabled: true,
face: Cesium.CullFace.FRONT
depthTest: {
enabled: false
depthMask: true,
blending: undefined
TrianglePrimitive.prototype.setupDrawCommand = function () {
this._drawCommand.modelMatrix = this._modelMatrix;
this._drawCommand.renderState = this._renderState;
this._drawCommand.primitiveType = Cesium.PrimitiveType.TRIANGLES;
this._drawCommand.shaderProgram = this._shaderProgram;
this._drawCommand.vertexArray = this.vertexArray;
this._drawCommand.pass = Cesium.Pass.OVERLAY;
this._drawCommand.boundingVolume = this.createBoundingVolume();
this._drawCommand.debugShowBoundingVolume = false;
TrianglePrimitive.prototype.createIndexBuffer = function (context) {
this._indicesArray = TrianglePrimitive.createIndicesArray(this._vertices.length);
this._indexBufferArray = Cesium.Buffer.createIndexBuffer({
context: context,
typedArray: this._indicesArray,
usage: Cesium.BufferUsage.STATIC_DRAW,
indexDatatype: Cesium.IndexDatatype.UNSIGNED_SHORT
TrianglePrimitive.createIndicesArray = function (size) {
var indicesArray = [];
for (var i = 0; i < size / 3; i++) {
indicesArray.push(i);
return new Uint16Array(indicesArray);
TrianglePrimitive.prototype.createBoundingVolume = function () {
return Cesium.BoundingSphere.fromPoints(this._positions);
return TrianglePrimitive;
var pri = new TrianglePrimitive({
positions:Cesium.Cartesian3.fromDegreesArrayHeights([-111.0, 40.0, 150000.0,-111,45,150000,-100,40.5,150000])
viewer.scene.primitives.add(pri);
Sandcastle.addToolbarButton(‘change’, function() {
pri.positions = Cesium.Cartesian3.fromDegreesArrayHeights([-120.0, 40.0, 150000.0,-120,45,150000,-109,40.5,150000]);
I wonder why the old triangle doesn’t disappear and how to clear the old triangle.
Any help appreciated.
Thanks
Chris
