How to apply bloom effect to a single object?
I want to apply a bloom effect to a single object. I looked at the post-processing of cesium. It seems that the bloom effect can only be applied globally.
per-feature post-processing bloom effect.
I want to draw some geometry, the surface of the geometry is a transparent material, the outline of the geometry is applied to the bloom effect, and the reason for using the bloom effect is to highlight the outline and look beautiful.
cesium1.5.9,windows 10 x64,chrome 75.0.3770.100.
Hey Jalien,
Thanks for bringing this up! Looks like the bloom shader just doesn’t check for the selected feature property. I opened a feature request for it here with some suggestions on how this can be accomplished:
https://github.com/AnalyticalGraphicsInc/cesium/issues/7984
Do note that feature selection currently only works for models/primitives, not entities.
I changed the BloomComposite.glsl code as follows,then rebuild cesium, but the problem persists.
uniform sampler2D colorTexture;
uniform sampler2D bloomTexture;
uniform bool glowOnly;
varying vec2 v_textureCoordinates;
void main(void)
vec4 color = texture2D(colorTexture, v_textureCoordinates);
#ifdef CZM_SELECTED_FEATURE
if (czm_selected()) {
gl_FragColor = color;
return;
#endif
vec4 bloom = texture2D(bloomTexture, v_textureCoordinates);
gl_FragColor = glowOnly ? bloom : bloom + color;
在 2019年7月8日星期一 UTC+8下午10:24:12,Omar Shehata写道:
Did you verify that the CZM_SELECTED_FEATURE definition was getting added to the shader? There might be a step I missed for that in the PostProcessStage class to add that definition when constructing the shader.
Hi,Omar,Thank you for your reply.
The CZM_SELECTED_FEATURE is defined here, I debug the code, after running this line of code, the shader code is as follows:
#define CZM_SELECTED_FEATURE
uniform sampler2D czm_idTexture;
uniform sampler2D czm_selectedIdTexture;
uniform float czm_selectedIdTextureStep;
bool czm_selected(vec2 offset)
bool selected = false;
vec4 id = texture2D(czm_idTexture, v_textureCoordinates + offset);
for (int i = 0; i < 1; ++i)
vec4 selectedId = texture2D(czm_selectedIdTexture, vec2(float(i) * czm_selectedIdTextureStep, 0.5));
if (all(equal(id, selectedId)))
return true;
return false;
bool czm_selected()
return czm_selected(vec2(0.0));
void main(void)
return;
#endif
在 2019年7月10日星期三 UTC+8上午2:11:47,Omar Shehata写道:
