ThreeJS has an applyQuaternion on a vector to achieve a rotation of the vector. So a circle can be created for example by rotating the unit vector around an axis with vector.applyQuaternion()
Is there an way to do this in Cesium with Cartesian3 and Quaternion?
In threeJS:
step is a quaternion defined like this:
step.setFromAxisAngle(new Three.Vector3(0, 1, 0),
Three.Math.degToRad(360 / tesselation));
for the number of steps around the circle:
vector.applyQuaternion(step);
I want to collect the vertices of a circle for example.
I'd like to use quaternions if possible for flexibility.
"cesium": "1.48.0", windows 10, Version 74.0.3729.131 (Official Build) (64-bit)
