How to calculate Cartesian3 in postProcessStages shader
I****write a postProcessStages shader. I need to calculate Cartesian3 by gl_FragCoord.xy and depth. What should I do?
var fragmentShaderSource =
uniform sampler2D depthTexture;
varying vec2 v_textureCoordinates;
uniform sampler2D colorTexture;
void main(void)
float depth = czm_readDepth(depthTexture, v_textureCoordinates);
// what should I do ?
vec3 cartesian3 = getCartesian3(gl_FragCoord.x, gl_FragCoord.y, depth);
What exactly are you trying to compute? Are you trying to get the position in world space at this pixel?
Can you explain a bit more about what type of effect you’re trying to create?
Yes, I want to get the position in world space at this pixel.
Is there a way to achieve it ?
