How to calculate polygon area and line length on terrain?
I am using Sandcastle example for drawing on terrain.
I am interested to calculate polygon area and line length as shown in images below. After calculating area and length I am interested to save polygon in geojson format.
Anyone tell me how to calculate area of polygon and how to save polygon in geojson file in server?
I am trying below code to calculate area and length of polygon and line.
Could you please check error…
Uncaught DeveloperError: normalized result is not a number
Error
at new DeveloperError (http://localhost/cesiumjs/Source/Core/DeveloperError.js:43:19 )
at Function.Cartesian3.normalize (http://localhost/cesiumjs/Source/Core/Cartesian3.js:421:19 )
at Function.Cartographic.fromCartesian (http://localhost/cesiumjs/Source/Core/Cartographic.js:132:24 )
at startup (:109:50)
at Object.execCb (http://localhost/cesiumjs/ThirdParty/requirejs-2.1.20/require.js:1678:33 )
at Module.check (http://localhost/cesiumjs/ThirdParty/requirejs-2.1.20/require.js:878:51 )
at Module. (http://localhost/cesiumjs/ThirdParty/requirejs-2.1.20/require.js:1128:34 )
at http://localhost/cesiumjs/ThirdParty/requirejs-2.1.20/require.js:131:23
at http://localhost/cesiumjs/ThirdParty/requirejs-2.1.20/require.js:1178:21
at each (http://localhost/cesiumjs/ThirdParty/requirejs-2.1.20/require.js:56:31) (on line 421 of http://localhost/cesiumjs/Source/Core/Cartesian3.js)
selectionIndicator : false,
infoBox : false,
terrainProvider : Cesium.createWorldTerrain()
viewer.cesiumWidget.screenSpaceEventHandler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
function createPoint(worldPosition) {
var point = viewer.entities.add({
position : worldPosition,
point : {
color : Cesium.Color.WHITE,
pixelSize : 5,
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND
return point;
var drawingMode = ‘line’;
function drawShape(positionData) {
var shape;
if (drawingMode === ‘line’) {
shape = viewer.entities.add({
polyline : {
positions : positionData,
clampToGround : true,
width : 3
else if (drawingMode === ‘polygon’) {
polygon: {
hierarchy: positionData,
material: new Cesium.ColorMaterialProperty(Cesium.Color.WHITE.withAlpha(0.7))
return shape;
var activeShapePoints = ;
var activeShape;
var floatingPoint;
var handler = new Cesium.ScreenSpaceEventHandler(viewer.canvas);
handler.setInputAction(function(event) {
// We use viewer.scene.pickPosition here instead of viewer.camera.pickEllipsoid so that
// we get the correct point when mousing over terrain.
var earthPosition = viewer.scene.pickPosition(event.position);
// earthPosition will be undefined if our mouse is not over the globe.
if (Cesium.defined(earthPosition)) {
if (activeShapePoints.length === 0) {
floatingPoint = createPoint(earthPosition);
activeShapePoints.push(earthPosition);
var dynamicPositions = new Cesium.CallbackProperty(function () {
return activeShapePoints;
}, false);
activeShape = drawShape(dynamicPositions);
if (Cesium.defined(floatingPoint)) {
var newPosition = viewer.scene.pickPosition(event.endPosition);
if (Cesium.defined(newPosition)) {
floatingPoint.position.setValue(newPosition);
activeShapePoints.pop();
activeShapePoints.push(newPosition);
// Redraw the shape so it’s not dynamic and remove the dynamic shape.
function terminateShape() {
drawShape(activeShapePoints);
viewer.entities.remove(floatingPoint);
viewer.entities.remove(activeShape);
floatingPoint = undefined;
activeShape = undefined;
terminateShape();
}, Cesium.ScreenSpaceEventType.RIGHT_CLICK);
var options = [{
text : ‘Draw Lines’,
onselect : function() {
terminateShape();
text : ‘Draw Polygons’,
terminateShape();
drawingMode = ‘polygon’;
Sandcastle.addToolbarMenu(options);
// Zoom in to an area with mountains
viewer.camera.lookAt(Cesium.Cartesian3.fromDegrees(-122.2058, 46.1955, 1000.0), new Cesium.Cartesian3(5000.0, 5000.0, 5000.0));
viewer.camera.lookAtTransform(Cesium.Matrix4.IDENTITY);
var startCartographicPoint = Cesium.Cartographic.fromCartesian(activeShapePoints);
var endCartographicPoint = Cesium.Cartographic.fromCartesian(activeShapePoints);
var ellipsoidGeodesic = new Cesium.EllipsoidGeodesic(startCartographicPoint,
endCartographicPoint );
var distance = ellipsoidGeodesic.surfaceDistance;
var distanceInKm = distance * 0.001;
console.log(‘Geodesic distance: ’ + distanceInKm + ’ Km’);
Cesium 1.47, Chrome, Window 8.1
