I am using this code to animate a polyline ( I took it from this topic ) :
var viewer = new Cesium.Viewer(‘cesiumContainer’, {timeline : false, animation : false});
var pinBuilder = new Cesium.PinBuilder();
var bluePin = viewer.entities.add({
name : ‘Blank blue pin’,
position : Cesium.Cartesian3.fromDegrees(-75.170726, 39.9208667),
billboard : {
image : pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 48).toDataURL(),
verticalOrigin : Cesium.VerticalOrigin.BOTTOM
var questionPin = viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(-75.1698529, 39.9220071),
billboard : {
image : pinBuilder.fromText(’?’, Cesium.Color.BLACK, 48).toDataURL(),
function createLineAnimation(startEntity, endEntity, duration){
var startTime = performance.now();
return new Cesium.CallbackProperty(function(time, result){
if(!Cesium.defined(result)){
result = ;
var now = performance.now();
var start = startEntity.position.getValue(time, result[0]);
var end = endEntity.position.getValue(time, result[1]);
var t = Math.min(1.0, (now - startTime) / duration);
Cesium.Cartesian3.lerp(start, end, t, end);
result[0] = start;
result[1] = end;
result.length = 2;
return result;
}, false);
Sandcastle.addToolbarButton(‘Go’, function(){
polyline: {
positions : createLineAnimation(bluePin, questionPin, 2000)
Now if I want to capture animation frames as a image and make a video out of it, how will I do that?
. I just came across the toDataURL() method which i can call on cesium canvas to capture the image of canvas. I wanted to ask which approach is better, the one you described or the one with toDataURL(). I find toDataURL() method quite easy to use but are there any hidden problems which i might face in future.
