How to change camera zoom, heading and pitch while tracking an entity?
I am using following code to animate a polyline and a pin on a given path:
function tick() {
iterator++;
console.log(“tick”);
var strt_pos = positions[positions.length-1];
var end_pos = Cesium.Cartesian3.fromDegrees(cods[iterator][0],cods[iterator][1]);
var cart_strt_pos = Cesium.Ellipsoid.WGS84.cartesianToCartographic(strt_pos);
var cart_end_pos = Cesium.Ellipsoid.WGS84.cartesianToCartographic(end_pos);
var geodesic = new Cesium.EllipsoidGeodesic(cart_strt_pos, cart_end_pos, ellipsoid);
var duration = geodesic.surfaceDistance/800;
duration*=1000.0;
interpolate(performance.now(),duration, geodesic);
function interpolate(startTime, duration, geodesic){
var now = performance.now();
var t = Math.min(1.0, (now - startTime) / duration);
console.log(“intr”);
var cart = geodesic.interpolateUsingFraction(t);
var newpos = Cesium.Ellipsoid.WGS84.cartographicToCartesian(cart);
positions.push(newpos);
polyline.positions = positions;
entity.position = newpos;
if(t<1){
setTimeout(function() { interpolate(startTime, duration, geodesic); }, 16);
}else{
tick();
setTimeout(function() { tick(); }, 3000);
As you can see i have set viewer.trackedEntity=entity and enity is actually my pin (Billboard), therefore my camera is following it correctly. But the problem is that i want to change zoom, heading, and pitch of the camera at my wish. I tried different solution but to no avail. The problems i faced are:
  • viewer.camera.zoomOut() doesn’t work
  • and even if i set properties of camera using viewer.camera.setView prior to calling tick() function, the camera resets itself to default tracking orientation.
    How should I change camera zoom, heading, pitch and may be roll while tracking entity?
