How to change primitive node colors, gltf 2.0 vs gltf 1.0
With Cesium <= 1.96 and gltf 1.0, I can change a primitive’s colors like so
var primitive = viewer.scene.primitives._primitives[0]._primitives[0];
var material = primitive.getMaterial(materialName);
material.setValue(‘diffuse’, new Cesium.Cartesian4(1, 0, 0, 1));
But with Cesium 1.99 and gltf 2.0, I haven’t figured out the syntax to do so.
I can change the whole primitive’s color with
primitive.color = Cesium.Color.RED;
But to change a node’s color this doesn’t work
primitive.getNode(nodeName).color=Cesium.Color.RED;
However the node is accessible because this hides it
primitive.getNode(nodeName).show=false;
This also doesn’t work
primitive._loader._gltfJsonLoader._gltf.materials[0].pbrMetallicRoughness.baseColorFactor=[1, 0, 0, 1];
With Cesium 1.99 and gltf 2.0, how can I change a primitive’s nodes’ colors ?
Thank you for your help!
I figured it out!
Choose your primitive containing the node
var primitive = viewer.scene.primitives._primitives[0];
View node names like this
Object.keys(primitive._nodesByName);
Choose the node to be colored (1st one in this example)
var nodeName = Object.keys(primitive._nodesByName)[0];
Change the node’s color like this!
primitive.getNode(nodeName)._runtimeNode.node.primitives[0].material.metallicRoughness.baseColorFactor=Cesium.Cartesian4.fromColor(Cesium.Color.RED);
I got inspired by these posts :
Changing material of single mesh in model
How to color specific part of Model
First of all thank you for sharing codes. I’ve tried your solution but it doesn’t work. Check this sandcastle link.
I used the Primitive API, I haven’t tried with the Entity API.
viewer.entities.add uses the Entity API
Cesium.Model.fromGltf uses the Primitive API
I used this reference model to get the colors working with Cesium.Model.fromGltf
Hope this helps.
