I have created some billboards and some labels, and I’d like to put them in a cluster to control their visibility through pixelRange.
I’ve read that I need to create a dataSource, but how to create a dataSource from entities?
viewer.entities.add({
position: Cesium.Cartesian3.fromDegrees(longitude, latitude),
billboard: {
image: ‘images/pin_icon.svg’,
width: 16.3,
height: 21.3,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
heightReference: Cesium.HeightReference.RELATIVE_TO_GROUND,
/// now I should put this entity in a dataSource / cluster
1.61
