Hello
I’d like to know if is possible to customize the default Cesium UI (the timeline, the top buttons, etc),
and how.
Many thanks
Hello
and how.
Many thanks
You can turn off everything in the viewer widget and add your own UI elements instead, you can read a bit about that in the Cesium Workshop here:
https://cesium.com/docs/tutorials/cesium-workshop/#creating-the-viewer
Otherwise, you could modify the source for the HTML/CSS elements. Every widget should have a “ViewModel” class. For example, here’s the animation widget’s view model:
And its corresponding styling:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Widgets/Animation/Animation.css
