How to display underground object (tunnel, plumbing and etc)
I want to build a 3D map that will show underground objects, how do I display underground objects in Cesium?
1.65
Underground rendering isn’t currently fully supported (there’s a few tricks you can now like clipping out the terrain and visualizing your objects that way), but we are working on it! See this issue for updates: https://github.com/AnalyticalGraphicsInc/cesium/issues/5665
