How to draw lines on the side faces of a extrude polygon volume
I want to draw this kind of geometry
The problem is how to draw lines on the side faces of polygon volume perfectly.
I tried to use drawing polylines but not perfect.
Any help would be thankful.
Hi @ZhefengJin,
A wall geometry is probably best suited to your use case. You should be able to apply a texture to get the lines.
Gabby
