How to get intersection of a ray from the camera and 3d terrain?
I need to get the intersection point of a ray from the camera to 3d terrain.
Cesium.IntersectionTest() seem to use only the ellipsoid,
var intersectionPoint = function(){
var ellipsoid = viewer.scene.mapProjection.ellipsoid;
var windowCoordinates = new Cesium.Cartesian2(elmnt.offsetHeight / 2, elmnt.offsetWidth / 2);
var ray = viewer.camera.getPickRay(windowCoordinates);
var intersection = Cesium.IntersectionTests.rayEllipsoid(ray, ellipsoid);
return Cesium.Ray.getPoint(ray, intersection.start);
This function return a Cartesian3 with height (from 3d terrain), but not picked in the center of the window.
What I need is to trace a ray from the camera and get the very first intersection with the 3d terrain.
I need to rotate the camera around the 1st picked intersection of a ray from the camera (from the center of the window) and the 3d terrain
1.60
This is the solution:
var intersectionPoint = viewer.scene.globe.pick(ray, viewer.scene);
@Daniele_Suppo
Can you please tell me how you are getting elmnt.offsetHeight in the above line.
