omar
#2
Cesium recently added support for Pelias (https://pelias.io/) an open source geocoder which should let you do what you need. I think what you’re looking for is reverse geocoding (https://github.com/pelias/documentation/blob/master/reverse.md).
And then check the Cesium docs for how to use it with Cesium: https://cesiumjs.org/Cesium/Build/Documentation/PeliasGeocoderService.html
I hope this helps!
