If I set vertices to (x, y, 0) so that the polyline is in the X-Y plane, the polyline renders fine. If I use (x, 0 , z) so the polyline is in the X-Z plane, it doesn't render the polylineGeometry correctly. The vertices are correct and can be plotted in another drawing program. I set VertexFormat positions to true for 3D.
const template = new Cesium.PolylineGeometry({
positions: vertices,
width: 4,
vertexFormat: new Cesium.VertexFormat({
position : true,
where vertices are an array of (x, 0, z) values like
0.08715574274765804, 0, 1.9961946980917455,
0.1736481776669302, 0, 1.9848077530122081,
0.25881904510252063, 0, 1.9659258262890684,
0.3420201433256686, 0, 1.9396926207859084,
Trying to draw a polyline primitive geometry in the X-Z plane
"cesium": "1.48.0"
chrome Version 73.0.3683.103 (Official Build) (64-bit)
