Hello I should fly on the map preserving the heading, pitch and range from user interaction.
I can get actual pitch and heading, but I don’t know how to get the actual range
can you help me?
thanks!
function flyMapToPin(){
heading = mapCamera.heading;
pitch = mapCamera.pitch;
range = 764.534479411941; // Here I should get the actual range
viewer.flyTo(pin, {
offset: new Cesium.HeadingPitchRange(heading, pitch, range)
To keep the same distance
1.60
