How to get the primitive associated with an entity?
Entity API is very convenient and powerful but sometimes primitives give more options and flexibility.
For example, we can control animations for primitive models through a ModelAnimationCollection, we can position a label primitive more precisely through label position property.
Before Cesium version 1.26 I used such routine to get to a label primitive associated with an entity.
Two stages - 1) finding a LabelCollection in a Scene PrimitivesCollection. and then 2) finding a right label by a reference to an entity
function getLabelForEntity(entity) {
    var primitives = viewer.scene.primitives;
    var primitive;
    for (var i = 0; i < primitives.length; i++) {
        primitive = primitives.get(i);
        if (primitive instanceof Cesium.LabelCollection) {
            var labelCollection = primitive;
            if (!labelCollection) return undefined;
            var label;
            for (var j = 0; j < labelCollection.length; j++) {
                label = labelCollection.get(j);
                if (label instanceof Cesium.Label && label.id === entity) {
                    return label;
    return undefined;
Something similar was recommended in this forum for models
function getModelForEntity(entity) {
    var primitive;
        if (primitive instanceof Cesium.Model && primitive.id === entity) {
            return primitive;
This approach (at least for Labels and Billboards) doesn’t work after introduction of EntityCluster in v.1.26
I can adopt my routines, but before doing that I’d like to ask if I’m doing a wrong thing and is there an other way to get to the needed primitive in an entity?
Thank you,
Vladimir.
