how to lighlight a gltf model?
Hi
I want highlight a model,and i use the EntityModelColor.js,the link https://gist.github.com/mramato/2b6becee077c664bf25d
     //scene.context.createTexture2D is not part of the public API,
    //so this code may have to change in the future.
    var texture = viewer.scene.context.createTexture2D({
        source : image
,but the texture is not part of the public API,and I use
var texture = Cesium.Material.fromType('Image', {
            path:'../images/checkerboard.png'
to replace it,the model is changed,but it's not what i want ,The first material picture is cesium logo,and the replace picture is checkerboar.png .
If i want highlight the model,what should i do ? this is my code in Sandcastle:
    infoBox : false,
    selectionIndicator : false
    position : Cesium.Cartesian3.fromDegrees(-123, 44, 10),
    model : {
        uri : '../../../Specs/Data/Models/Box-Textured/CesiumTexturedBoxTest.gltf',
        minimumPixelSize : 128
viewer.zoomTo(entity, new Cesium.HeadingPitchRange(Math.PI / 4, -Math.PI / 4, 3));
Cesium.loadImage('../images/checkerboard.png').then(function(image) {
    //Change color on mouse over. This relies on the fact that given a primitive,
    //you can retrieve an associted en
    console.log(1);
    var originalTexture;
    var lastPick;
    var handler = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas);
    var material;
    handler.setInputAction(function(movement) {
        var primitive;
        var pickedObject = viewer.scene.pick(movement.endPosition);
        if (pickedObject) {
            primitive = pickedObject.primitive;
            if (pickedObject !== lastPick && primitive instanceof Cesium.Model) {
                //We don't use the entity here, but if you need to color based on
                //some entity property, you can get to that data it here.
                var entity = primitive.id;
                material = primitive.getMaterial('Texture');
                originalTexture = material.getValue('diffuse');
                console.log(originalTexture);
                material.setValue('diffuse', Sandcastle);
                lastPick = pickedObject;
        } else if (lastPick) {
            primitive = lastPick.primitive;
            material.setValue('diffuse', originalTexture);
            lastPick = undefined;
//Ability to look up the Model associated with an entity
function getModelForEntity(entity) {
    var primitives = viewer.scene.primitives;
    for (var i = 0; i < primitives.length; i++) {
        var primitive = primitives.get(i);
        if (primitive instanceof Cesium.Model && primitive.id === entity) {
            return primitive;
I can’t really help too much with the code sample since highlighting a textured model is not as straightforward. There is a branch in Cesium for handling model coloring that you can check out: https://github.com/AnalyticalGraphicsInc/cesium/pull/4547.
Thank you very much,Sean!
I'm trying other ways,may reach my goal!
