I’m trying to achieve the functionality to change the property of the model using model name. (e.g. changing the color of the loaded 3D model). I can achieve this functionality using mouse picking. The code is detailed below.
var handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
handler.setInputAction(
function (movement) {
var pick = scene.pick(movement.endPosition);
if (Cesium.defined(pick) && Cesium.defined(pick.node) && Cesium.defined(pick.mesh)) {
console.log('node: ' + pick.node.name + '. mesh: ' + pick.mesh.name);
Cesium.ScreenSpaceEventType.MOUSE_MOVE
From this I can get the materials from “pick.mesh._materials” But I wanted to do the same by sending the model name.
I’ve found the API to get the node or model from the name
e.g. model.getNode(‘model_name’) will give the mesh or node. But I could not found the materials inside.
Is there any other API to get the mesh by passing model_name or model_id ?
Advice/help is greatly appreciated!
