Hi
I used dragdrop feature for adding kml files to viewer . i will use a button for removing kml files . how can i remove them ? also there is other entities in viewer that i will not to they removed by this button.
Hi
Hi @mohamad,
Thank you for your question. If I’m not mistaken, you should be able to use the method destroy() of KmlDataSource. Here is the documentation for your reference.
https://cesium.com/learn/cesiumjs/ref-doc/KmlDataSource.html?classFilter=kml
Sam
Thank you much
how can i use the distory() ? Is there any example ?
I receive this error : Cesium.KmlDataSource.distroy is not a function .
It’s destroy(), spelling error.
You could remove it via DataSourceCollection#remove(), see: DataSourceCollection - Cesium Documentation.
like this:
viewer.dataSources.remove(dataSource)
Hi @Gu-Miao! Nice catch
