How to render polygon faster?
Polygon is initialized for the first time takes a long time, but the next time is much faster, how to make the polygon to initialize quickly the first time? here is my example using Left-click on features to show polygon Cesium Sandcastle
upppp
:sneezing_face: :sneezing_face: :sneezing_face: :sneezing_face:
Hi @Yen_Woody,
Thank you for sharing such a cool sandcastle demo with our community! I ran your demo various times in different browsers. I did not experience any significant or noteworthy amount of latency.
Is it possible that this issue is mostly related to the strength of your broadband access?
I also took some time to look through your code. I did not see any “red flags” in terms of optimization. Is there a particular part of your code that you believe is inefficient? I am looking forward to hearing from you and learning more!
-Sam
i tried initializing datasource polygon
const dataSource = new Cesium.CustomDataSource("custom");
        const redPolygon = dataSource.entities.add({
            polygon: {
                hierarchy: Cesium.Cartesian3.fromDegreesArray([-115.0, 37.0,
                -115.0, 32.0,
                -107.0, 33.0,
                -102.0, 31.0,
                -102.0, 35.0]),
                material: Cesium.Color.RED.withAlpha(0.001)
and it works faster
@Yen_Woody, thanks for sharing your problem and best of all, your solution!
@Yen_Woody
Thank you for sharing this update! I am happy to hear that you were able to resolve your issue.
-Sam
I met the identical problem. Using devtools, I noticed when I try to render a polygon or polyline on the ground (where its height need to be resampled according to the local height) for the first time after refreshing, a few xxxshader.js are loaded in sequence, and each of them takes about one second.
I am located in mainland China, is that the problem?
@Inu_Dog
Welcome to the community! Out of curiosity, why do you suspect that your location could be related to this issue? I suspect that the latency that you are noticing is due to caching within the browser. Regardless, I am looking forward to learning more!
-Sam
