how to rotate cylinder in cesium
hi there,
i am creating a cylinder but the rotation is not working could u please help me
var greenCylinder = viewer.entities.add({
name : ‘Green cylinder with black outline’,
position: Cesium.Cartesian3.fromDegrees(-100.0, 40.0, 200000.0),
cylinder : {
length : 400000.0,
topRadius : 200000.0,
bottomRadius : 200000.0,
rotation: Cesium.Math.toRadians(90),
material : Cesium.Color.GREEN.withAlpha(0.5),
outline : true,
outlineColor : Cesium.Color.DARK_GREEN
Hi!
I don’t think you can specify a “rotation” attribute to the cylinder since that isn’t specified in the API. You would have to specify an orientation attribute to the entity. Check out this related forum question for a code example. I copy-pasted the code that would be relevant. I changed a line about HeadingPitchRoll to conform to our most recent API.
var position = Cesium.Cartesian3.fromDegrees(-75, 40);
//Original, non-rotated cone for comparison.
viewer.entities.add(new Cesium.Entity({
position: position,
point: {
color: Cesium.Color.YELLOW,
show: true,
pixelSize: 20
cylinder: {
topRadius: 0,
bottomRadius: 5,
length: 20,
material: Cesium.Color.YELLOW.withAlpha(0.5)
//Create a rotation
var orientation = Cesium.Transforms.headingPitchRollQuaternion(
position,
new Cesium.HeadingPitchRoll(Cesium.Math.toRadians(0.0),
Cesium.Math.toRadians(90.0)));
//Since the rotate is in the center, we need to offset it
//by the length in the north direction.
var offset = new Cesium.Cartesian3(0, 10, 0);
//Create a transform for the offset.
var enuTransform = Cesium.Transforms.eastNorthUpToFixedFrame(position);
//Transform the offset
Cesium.Matrix4.multiplyByPointAsVector(enuTransform, offset, offset);
//Add the offset to the original position to get the final value.
Cesium.Cartesian3.add(position, offset, position);
position: position,
orientation: orientation,
point: {
show: true,
pixelSize: 20
cylinder: {
topRadius: 0,
bottomRadius: 5,
length: 20,
Hope this helps!
