how to select items from the Viewer?
Hi, I’m Álex
In first place, thanks for your time.
I have a different questions about how to select items from the Viewer:
My first questions:
How can i select from a polygon elements in the visor?
My second question:
How can i select all elements from the viewer?
And finally
Exists any method in cesium for make this?
Thanks a million
Álex
Alex,
When you add an entity to the viewer, you can specify an id like this:
viewer.entities.add({
   id: 'some unique id',
Then you can find that entity by looking it up using the id:
var entity = viewer.getById('some unique id');
Read about this function here:
https://cesiumjs.org/Cesium/Build/Documentation/EntityCollection.html#getById
You can access all entities by:
var entities = viewer.entities.values;
Hope that help.
-Steven
Hi Steven,
In first place thanks for your time.
That isn't exactly what we need.
Actually we need.
From a polygon drawn manually i want to pick all items inside it.
Thanks a million.
Álex.
Hi Alex,
I’m not sure exactly what you mean here by elements. Do you mean entities? If so, picking might be the way to do so.
Gabby
Thanks a million.
Álex.
