Hello all,
have svg point billboards in Cesium 3D Map and would like to make them 20% opacity in certain cases, also use json file for styling where alpha = 0..x works for lines and areas, but not for svg point billboards.
.json snippet for particular billboard role >
“RP_BLUE_LIGHT”: {
“icon”: “./icons/RP_BLUE_LIGHT.svg”,
“scale”: 0.2
lines working fine with alpha, as shown in this snippet>
"Etapa": {
"color": "#0000FF",
"width": 7,
"alpha": 0.6
Any recommendation how to set transparency in code?
example of billboards in map
Hi @Davor_Fiedler,
So you want the billboard icon itself to have a transparency? I think what you want is the Color property of billboards, not alpha. Try adding a billboard with:
color: new Cesium.Color(1.0, 1.0, 1.0, 0.2) // 20% opacity
(That would be if you create the billboard in JS. Might be different if you’re defining the billboard in a json file). Let me know if that works.
Matt
Thank you Matt,
working now, like this:
if (dimmed) {
graphic\[propertyName\] = new Cesium.ConstantProperty(new Cesium.Color(1.0, 1.0, 1.0, 0.2));
} else if …
Best regards,
Davor
