How to use WebMapServiceImageryProvider or UrlTemplateImageryProvider with authentication token
We are using WebMapServiceImageryProvider and UrlTemplateImageryProvider which point to Open-ID authenticated services. Therefore we need to include an authentication token to the request. That works fine until the token is not valid anymore (which is the case after a few minutes), Once that happens, we need to update the authentication information.
Now, it is possible to use a “Resource” and add an appropriate “retryCallback”. However, inside this callback it is not possible to persist the updated authentication information. Cesium always first tries the original information, causing a lot of network traffic, server load and log messages which all could be avoided.
  • What is the intended way to use authenticated imagery providers?
  • Is it possible to intercept (any manipulate) the HTTP request?
Currently 1.62.0
OS and browser version is irrelevant, Cesium shows the exact same behaviour everywhere …
I think the easiest way to handle this would be to create a custom Resource class that wraps some logic around the Resource calls. Cesium ion uses OAuth, and so all resources loaded from ion have the same flow, where a token is required, and a new token is needed when that expires. This is all handled by the IonResource class, so you can use it as kind of a template for implementing a class for your service:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Core/IonResource.js
Let me know if this helps.
Thanks for your reply. It helped to direct me to the right path :wink:
I ended up just patching the “fetch” function of the Resource class:
     * Patches the original Cesium.Resource class to allow updating of authorization header in HTTP requests.
    private patchCesiumResource(): void {
        const orig = Cesium.Resource.prototype.fetch;
        // Store reference to the service, because "this" refers to the resource instance inside the patched function.
        const self = this;
        Cesium.Resource.prototype.fetch = function(callOptions: any) {
            if (this.headers.Authorization === 'system') {
                this.headers.Authorization = self.authentication;
            return orig.call(this, callOptions);
(I’m developing an Angular app, so the above code is TypeScript)
