Hi, I’m quite new to Cesium and mapping in general so please bear with me. I’m trying to load an ImageryProvider using WebMapTileServiceImageryProvider into our Cesium mapping application and I am getting 404’s when requesting tiles. The WMTS loads fine using QGIS.
The ImageServer is at https://maps.brucecounty.on.ca/arcgis/rest/services/public/swoop2015/ImageServer/WMTS/1.0.0/WMTSCapabilities.xml.
I believe the issue is related to the fact that the supported CRS of the image server is EPSG:26917. I think I need to use the GeographicTilingScheme.
Using the bounds for EPSG:26917 from QGIS:
var epsg_26917_rect = Cesium.Rectangle.fromDegrees(-84, 23.81, -78, 84);
var epsg_26917 = new Cesium.GeographicTilingScheme({
rectangle: epsg_26917_rect,
// numberOfLevelZeroTilesX: ?,
// numberOfLevelZeroTilesY: ?,
// ellipsoid: ?,
imageryProvider = new Cesium.WebMapTileServiceImageryProvider({
url: ‘https://maps.brucecounty.on.ca/arcgis/rest/services/public/swoop2015/ImageServer/WMTS’,
layer: ‘swoop2015’,
style: ‘default’,
tileMatrixSetID: ‘default028mm’,
tilingScheme: epsg_26917,
In the WMTSCapabilities.xml, it says the 0th layer has
84
76
so I tried that for numberOfLevelZeroTilesX and numberOfLevelZeroTilesY but that didn’t work. I was able to get values for these that appeared somewhat in the correct general area but the image was very skewed.
Am I supposed to use GRS80 insead of WGS84? How do I define that ellipsoid in Cesium?
I want to display hi-res local imagery in an internal mapping tool made with Cesium.
Cesium 1.63, Ubuntu 19.10, Chrome 78.0.3904.97
Thanks
