I don't think I am building this wms provider correctly
Hi there,
Could someone take a look at this WMS ?
http://wms.alaskamapped.org/ortho
and help me out with building a Cesium.WebMapServiceImageryProvider?
I have:
var spot = new Cesium.WebMapServiceImageryProvider({
url: ‘http://wms.alaskamapped.org/ortho’,
layers: 'ORTHO.RGB, //tried a bunch of different names out here
I am seeing a CORS error when the page loads, but I have seen those before when the problem ultimately was a poorly constructed url or parameter. I think I need to rule out the possibility that I am not referencing the layer properly.
thanks,
Evan
Hello Evan,
CORS issues usually have to do with how your server is configured. http://enable-cors.org/ is a good resource for learning about CORS and how to enable it.
I was able to get your imagery to load with the code you included in your post, so that’s not the problem.
Hannah
Hi Hannah,
Thanks for looking into that. Do you have an example I could see in the cesium online sandcastle?
I also found a TMS address:
http://tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{x}/{y}/{z}.png
and I can get this to work in a Leaflet fiddle app by simply adding
L.tileLayer('http://tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{x}/{y}/{z}.png').addTo(map)
But, again, when I try:
var spot = new Cesium.TileMapServiceImageryProvider({
  url: 'http://tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{x}/{y}/{z}.png',
  fileExtension: 'png'
it doesn't work. Same resource, same browser, and I am not doing anything to address CORS, what's the difference?
PS. I don't have any control over the server
Hi Evan,
You most likely have to enable CORS support on your own server. For example, we have a proxy route included in the server.js node script included with the Cesium download. If you run Sandcastle locally by doing node server.js, this code will work:
imageryProvider : new Cesium.WebMapServiceImageryProvider({
url: ‘//wms.alaskamapped.org/ortho’,
layers: ‘ORTHO.RGB’,
proxy : new Cesium.DefaultProxy(’/proxy/’)
baseLayerPicker : false
For the TMS server, consider using the UrlTemplateImageryProvider instead, since you know the template of the URL:
imageryProvider : new Cesium.UrlTemplateImageryProvider({
url: ‘//tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{x}/{y}/{z}.png’,
Hannah
Thanks again,
sorry I am so dense about CORS. I have read dozens of explanations and I only sort of get it. I will try this out.
