An image I created using a uniform latitude/longitude grid is not displayed correctly in Cesium. Here is an image showing the result: https://i.imgur.com/XOvheGD.jpg
The point labeled “ORP” should be co-located with where the red lines cross in the image.
Here is the image itself: https://i.imgur.com/riRqil1.png
// Point that should display at same location as central cross in image
entities.add({
parent : markers,
name : ‘Output Reference Point’,
position : Cesium.Cartesian3.fromDegrees(-83.506492, 42.230711),
point : {
pixelSize : 5,
color : Cesium.Color.RED,
outlineColor : Cesium.Color.WHITE,
outlineWidth : 2
label : {
text : ‘ORP’,
font : ‘14pt monospace’,
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth : 2,
verticalOrigin : Cesium.VerticalOrigin.BOTTOM,
pixelOffset : new Cesium.Cartesian2(0, -9)
// Image overlaid on the globe
var pattern = viewer.entities.add({
parent : beamPatterns,
name: ‘Beam Pattern’,
polygon: {
hierarchy: Cesium.Cartesian3.fromDegreesArray([
-98.528961, 57.248043,
-98.528961, 27.213378,
-68.484023, 27.213378,
-68.484023, 57.248043]),
height: 0,
outline: false,
material: new Cesium.ImageMaterialProperty({
image: ‘cesium_vis_test.png’,
transparent: true
Trying to display an image that I compute that shows an intensity function over an area of the earth. I have a function in Matlab where I can plug in a lat/lon value and get an intensity. I need to then display that map on top of the earth in Cesium. I just created an image with the intensity mapped to a color in each pixel on a uniform lat/lon grid, which seemed like the way to go since a Rectangle is always aligned to the lat/lon grid.
Cesium 1.42
Windows 10
Chrome
