What’s the different between interpolateHeight function and interpolateMeshHeight function in QuantizedMeshTerrainData,the two function get different results in my code.
the interpolateHeight function return 2496.909550352688
the interpolateMeshHeight function return undefined
var cartographic = Cesium.Cartographic.fromDegrees(104.931, 33.387);
var height=terrainData.interpolateHeight(terrainRectangle, cartographic.longitude, cartographic.latitude);
//terrainData level 3 ,x 12 ,y 2
//the source code from cesium
QuantizedMeshTerrainData.prototype.interpolateHeight = function(rectangle, longitude, latitude) {
var u = CesiumMath.clamp((longitude - rectangle.west) / rectangle.width, 0.0, 1.0);
u *= maxShort;
var v = CesiumMath.clamp((latitude - rectangle.south) / rectangle.height, 0.0, 1.0);
v *= maxShort;
if (!defined(this._mesh)) {
return interpolateHeight(this, u, v);
return interpolateMeshHeight(this, u, v);
Cesium 1.53
