Introducing CesiumJS Sandcastle Copilot
Hello Cesium Community,
Earlier this year, we opened a discussion about bringing a native AI Copilot into the CesiumJS Sandcastle workflow.
Thanks to the feedback and ideas shared in that thread, the first version of CesiumJS Sandcastle Copilot is now available in Sandcastle:
What is Sandcastle Copilot?
Sandcastle Copilot is an AI-assisted chat panel built directly into Sandcastle. It is designed to help developers move from an idea to working CesiumJS code faster, while keeping the normal Sandcastle workflow intact.
With Sandcastle Copilot, you can:
  • Ask questions about CesiumJS and the active Sandcastle
  • Request scene changes using natural language
  • Generate or edit JavaScript, HTML, and CSS
  • Review proposed code changes as diffs before applying them
  • Use console and runtime context to help diagnose errors
The goal is to reduce friction for people who are learning CesiumJS, including non-technical users and developers alike, while also speeding up prototyping for experienced users exploring new scene ideas, APIs, or datasets.
Bring Your Own Key
The initial release uses a bring-your-own-key model. Before starting a chat, you connect Sandcastle Copilot to an LLM provider you already use.
This keeps the first version lightweight and gives developers control over the model, API key, and account used for their conversations.
We’d Love Your Feedback
This is an initial release, and your feedback will help shape where it goes next.
A few areas where your input would be especially helpful:
  1. Your experience
    Have you tried Sandcastle Copilot yet? What did you ask it to build, explain, or debug?
  2. Sandcastle context
    Did Copilot understand the active Sandcastle and generate suggestions that were relevant to the code you were working with?
  3. Code review workflow
    Were the generated diffs easy to understand and review before applying?
  4. Debugging
    If you used Copilot with console errors or runtime issues, did it help you identify the problem?
  5. Missing capabilities
    What CesiumJS workflows should Sandcastle Copilot support next? For example:
    • Working with Cesium ion assets
    • Styling 3D Tiles
    • Managing camera views
    • Generating flight paths
    • Explaining unfamiliar CesiumJS APIs
    • Something else?
  6. Concerns
    What technical challenges, confusing behavior, or pitfalls should we be careful to avoid as this evolves?
Continuing the Conversation
This launch builds on the earlier feedback discussion here:
If you contributed there, thank you. That input helped clarify what would be most useful in an AI-assisted Sandcastle workflow.
Whether you are excited, skeptical, or just curious, we would love for you to try the first version and share what you find.
Try it here:
Looking forward to the discussion!
