I have Json data,at the time of loading data there is rendering error.I tried some solutions but still its not solved.
Error:
RangeError: Invalid array length
at Me (http://localhost/cesium/Build/Cesium/Cesium.js:552:18985)
at Ne (http://localhost/cesium/Build/Cesium/Cesium.js:552:21706)
at Ke (http://localhost/cesium/Build/Cesium/Cesium.js:553:84)
at Qe (http://localhost/cesium/Build/Cesium/Cesium.js:552:30061)
at ot (http://localhost/cesium/Build/Cesium/Cesium.js:553:4958)
at Ee.render (http://localhost/cesium/Build/Cesium/Cesium.js:553:12911)
at A.render (http://localhost/cesium/Build/Cesium/Cesium.js:566:8588)
at t (http://localhost/cesium/Build/Cesium/Cesium.js:565:23673)
Code:I tried these little bit code.
var data= Cesium.GeoJsonDataSource.load('geoserver-GetFeature.json');
console.log(data);
var entities;
data.then(function(dataSource){
viewer.dataSources.add(data);
viewer.zoomTo(data);
entities = dataSource.entities.values;
changeHeightStyle();
function changeHeightStyle(){
var entity;
var extrudedHeight;
for(var i=0; i<entities.length;i++){
entity = entities[i];
entity.polygon.outline = false;
extrudedHeight = entity.properties.GRIDCODE *1000;
entity.polygon.extrudedHeight = extrudedHeight;
var gridcodeh = entity.properties.GRIDCODE
entity.polygon.material = getColorHeight(gridcodeh);
colorlegend1.style.display = "block";
colorlegend2.style.display = "none";
I have Cesium 1.39,i tried with some other cesium versions also.Thanks
