Is it possible to display turf.js calulated buffer correctly?
Hello everybody,
I am calculating a buffer with turf.js and now i want to display it in cesium. The result is an oval shape instead of a circle.
I already did some investigation on this and as far as I understand it has to do something with the projection.
Long story short: is it somehow possible to display the calculated circle as a circle? Can some sort of transformation do the trick?
Thank you for any input on this!
In Turf you can try converting Buffer toMercator (EPSG: 900913) or toWgs84. Try these two projections and write down what happened :slightly_smiling_face:
Hi @kasatik143,
thanks a lot for your input, I´ve solved the problem by changing the scene mode to COLUMBUS_VIEW!
