Hi all,
I’m wondering if anyone has found a way to update single components of a czml file on-demand. Right now I have a couple java classes that write a czml file using the CesiumLanguageWriter. These get streamed to the Cesium server, converted to a string, parsed, and finally added to the viewer.
The problem I’m facing is finding a way to update components of the object after its creation. For example by default I have a yellow path turned on and written on the initial creation of the czml, how could I make it so there is a way to call some function to change the path color to red after it has been loaded into the viewer? Is there a way to send through a small patch-like object that will override the original value of components. Or will I need to write my own custom data-source to allow for this level of control over an object?
Chris
