Is there any example of using czmlwriter C# version?
Hi
I just started to learning the czml writer. If there is any example code or tutorial, that will help a lot.
thank you.
Chris
Here’s a little code that should give you an idea how it works.
Scott
        StringWriter sw = new StringWriter();
        CesiumOutputStream czOutputStream = new CesiumOutputStream(sw);
        czOutputStream.PrettyFormatting = true;
        CesiumStreamWriter czStreamWriter = new CesiumStreamWriter();
        // A CZML file contains an array of objects which the following opens.
        czOutputStream.WriteStartSequence();
        // Create the document czPacket
        PacketCesiumWriter czPacket = czStreamWriter.OpenPacket(czOutputStream);
        czPacket.WriteId("document");
        czPacket.WriteVersion("1.0");
        czPacket.Close();
        // Create packet for an object
        czPacket.WriteId("ID_0001");
        czPacket.WriteName("Name_0001");
        // Add position to object's packet
        PositionCesiumWriter czPosition = czPacket.OpenPositionProperty();
        czPosition.WriteCartographicDegrees(
            new Cartographic(-75.5966, 40.0386, 0.0));
        czPosition.Close();
        // Add label to object's packet
        LabelCesiumWriter czLabel = czPacket.OpenLabelProperty();
        czLabel.WriteTextProperty("Exton");
        czLabel.Close();
        // Add point to object's packet
        PointCesiumWriter czPoint = czPacket.OpenPointProperty();
        czPoint.WritePixelSizeProperty(5.0);
        czPoint.WriteOutlineWidthProperty(2.0);
        czPoint.WriteColorProperty(Color.DodgerBlue);
        czPoint.WriteOutlineColorProperty(Color.White);
        czPoint.Close();
        // Close the object's packet
        czPacket.Close();
        // Closes the array
        czOutputStream.WriteEndSequence();
        sw.Close();
Thanks Scott. That helps a lot.
在 2015年10月26日星期一 UTC+8上午9:37:03,Scott Reynolds写道:
