When i'm trying to compare the tiles with its features and color/style them accordingly, i'm not getting the exact result due tile load issue.
so is there any way to color/style the Tiles without defining the Tileset.
Cesium 1.47, windows 7, google chrome
I don’t follow what you mean by “without defining the tileset”, as you need to have a tileset in order to apply any style to its features. Can you clarify what you want to do exactly?
You can update the style whenever, like when a tile becomes visible. Also, you can define a function rather than using a style expression:
var style = new Cesium.Cesium3DTileStyle();
// Override color expression with a custom function
style.color = {
evaluateColor : function(frameState, feature, result) {
return Cesium.Color.clone(Cesium.Color.WHITE, result);
But it looks like the docs are missing for FrameState (I created an issue to fix that here). In the mean time, I believe what gets passed is an object of this class:
