When using css transform to scale the Cesium container, the entity inside could not get picked.
Here is the codesandbox that illustrate the issue:
https://codesandbox.io/s/keen-tharp-pdkv3?file=/src/index.js
The Cesium container css in style.css as below:
#app {
width: 400px;
height: 400px;
/* below lines cause entity cannot be clicked */
transform-origin: left top;
transform: scale(0.9, 0.9);
When remove the transform lines, the red dot on map can be clicked and shows the alert.
When add the two lines, the red dot not respond to click event.
Is this a bug, or what should I do to make it work with css transform?
