Issue with Cesium Terrain Provider
Polygon seems to be shifting after adding terrain effect in Cesium
I add a Polygon through geojson. In which i had added a terrain effect using the standard cesium terrain provider as below
I would like to know how to Lock the Polygon after adding the terrain and The Polygon will be fastened to the terrain when i move or turn the earth.
//add cesiumTerrainProvider
var cesiumTerrainProvider = new Cesium.CesiumTerrainProvider({
url: '//assets.agi.com/stk-terrain/world'
viewer.terrainProvider = cesiumTerrainProvider;
// This array will hold our cartographic height queries, one per building, and will
// also be populated with the answers.
var terrainSamplePositions = ;
var dataSource2 = new Cesium.GeoJsonDataSource();
var promise = dataSource2.load('geojson/t112.geojson');
promise.then(function(dataSource2) {
viewer.dataSources.add(dataSource2);
viewer.zoomTo(dataSource2);
//Get the array of entities
var entities2 = dataSource2.entities.values;
var colorHash = {};
for (var i = 0; i < entities2.length; i++) {
var entity = entities2[i];
var name = entity.Area;
var color = colorHash[name];
if (!color) {
color = Cesium.Color.BROWN;
colorHash[name] = color;
entity.polygon.material = color;
entity.polygon.outline = false;
// TODO: More sanity checking for undefined values etc.
var position = entity.polygon.hierarchy.getValue().positions[0];
terrainSamplePositions.push(Cesium.Cartographic.fromCartesian(position));
var TopHeight=entity.properties.TopHeight;
var BaseHeight=entity.properties.BaseHeight
var modelHeight=TopHeight - BaseHeight;
// entity.polygon.extrudedHeight = modelHeight;
// entity.polygon.height = BaseHeight;
// Asking for terrain heights is asynchronous, because the answer may
// reside on the terrain server.
Cesium.when(Cesium.sampleTerrain(viewer.terrainProvider, 11, terrainSamplePositions), function() {
// Update all building heights to sit on top of the terrain.
var terrainHeight = terrainSamplePositions[i].height;
// The bottom of the building sits on the terrain.
}).otherwise(function(error){
//Display any errrors encountered while loading.
console.error(error);
