Hi, I have got a mesh (available here http://the.ndero.ovh/file/test.glb) with the following geometry (computed from meshlab)
Mesh Bounding Box Size 50.301025 38.867523 11.987793
Mesh Bounding Box Diag 64.688362
Mesh Bounding Box min -647.150513 -397.717010 1164.604736
Mesh Bounding Box max -596.849487 -358.849487 1176.592529
Mesh Surface Area is 1476.913086
Mesh Total Len of 101173 Edges is 23624.369141 Avg Len 0.233505
Mesh Total Len of 101173 Edges is 23624.369141 Avg Len 0.233505 (including faux edges))
Thin shell (faces) barycenter: -616.792358 -372.915894 1170.946899
Vertices barycenter -616.030273 -372.015015 1171.141113
Mesh is not ‘watertight’, no information on volume, barycenter and inertia tensor.
Principal axes are :
-0.248451 -0.302277 0.920272 |
-0.057258 -0.943818 -0.325469 |
0.966951 -0.133556 0.217185
The mesh is not displayed with cesiumjs. I guess this is an issue related to geometry, but I’m not sure how to fix it.
var Cesium = require(‘cesium/Cesium’);
require(’./css/main.css’);
require(‘cesium/Widgets/widgets.css’);
infoBox : false,
selectionIndicator : false,
shadows : true,
skyBox:false,
shouldAnimate : true,
globe:false,
function createModel(url, height) {
viewer.entities.removeAll();
var position = Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0503706, height);
var heading = Cesium.Math.toRadians(135);
var pitch = 0;
var roll = 0;
var hpr = new Cesium.HeadingPitchRoll(heading, pitch, roll);
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
position : position,
orientation : orientation,
model : {
uri : url,
minimumPixelSize : 1,
maximumScale : 20000
createModel(‘output/Samples/test.glb’, 1000);
For display purpose.
1.60, MacOS, firefox
