Issue With Imagery Layers on iOS 11
When multiple imagery layers are added (either via WMTS or multiple static ImageryProvider instances), mobile Safari displays black tiles along the curvature of the Earth.
https://jsfiddle.net/kzaxupj1/41/
Just copy/pasted your WMTS sample to jsFiddle because the Cesium Sandcastle interface is not even slightly mobile-friendly. Zoom in to the active area and notice the black tiles appear every once in a while during animation. Always along the curvature of the Earth.
I have a separate implementation where this issue appears after adding multiple (3) static layers (MVT renders or just plain Imagery).
I just finished writing Mapbox Vector Tile support into Cesium on my development version. It exacerbated this bug. However, the above sample is the best way to demonstrate it.
Latest. Mobile Safari on latest iOS 11.
Similar reports have popped up on the forum in the past, but I could never reproduce them (including your example) on my iPhone 7 with latest iOS 11.
I believe it may be a hardware limitation or driver bug rather than apply to all of iOS and mobile Safari.
What type and model of iOS device you are using?
Tested on both an iPad Air 2 (10") and an iPhone 6. Both devices used to work fine.
https://youtu.be/qleh7h_YEvM
When you say “used to work fine” do you mean with previous versions of iOS or previous versions of Cesium? Can you try narrowing down which version of Cesium (or even better, which git commit) broke things? That would go a long way to helping us fix the issue.
Just for info, I can still reproduce this today on an iPad Air 2 with iOS 12.1 running Cesium 1.51
When adding an extra imageryLayer using viewer.imageryLayers.add, the base layer shows intermittent missing tiles (black) where the extra layer is loading content.
Thanks for letting us know Xavier. I’m trying to collect more info to open up a GitHub issue (https://github.com/AnalyticalGraphicsInc/cesium) for it. Does this happen for you in this imagery layers Sandcastle:
Or any of the imagery layers Sandcastle examples?
