.js willReadFrequently
I just started adding count(s) labels to the top of arrows on my globe, and when I did, I started getting these warnings
Canvas2D: Multiple readback operations using getImageData are faster with the willReadFrequently attribute set to true. See:
Cesium.js:1 Canvas2D: Multiple readback operations using getImageData are faster with the willReadFrequently attribute set to true. See: HTML Standard
This is the code I am using to produce the arrows and labels:
                            // Calculate position for the arrow and label
                            const position = Cesium.Cartesian3.fromDegrees(stateLongitude, stateLatitude, 600000); // Set height with offset
                            // Create black arrow representing the outage
                            const arrowEntity = viewer.entities.add({
                                position: position,
                                polyline: {
                                    positions: [position, Cesium.Cartesian3.fromDegrees(stateLongitude, stateLatitude, 0)], // Set height to 0 for the arrow's base
                                    width: 2, // Set width to 2px
                                    material: new Cesium.ColorMaterialProperty(Cesium.Color.BLACK) // Set color to black
                                description: `State: ${state}<br>Outage Count: ${outageCount}`
                            // Add label to display outage count aligned with the arrow
                                position: position,
                                label: {
                                    text: `${outageCount}`,
                                    font: '14px sans-serif',
                                    fillColor: Cesium.Color.YELLOW,
                                    style: Cesium.LabelStyle.FILL_AND_OUTLINE,
                                    outlineWidth: 2,
                                    outlineColor: Cesium.Color.RED,
                                    horizontalOrigin: Cesium.HorizontalOrigin.CENTER,
                                    verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
                                    pixelOffset: new Cesium.Cartesian2(0, 0), // Offset to position the label above the arrow
                                    pixelOffsetScaleByDistance: new Cesium.NearFarScalar(1.0e3, 1.0, 1.5e6, 0.2),
                                    willReadFrequently: true
And it is the second part which triggers the warnings. It’s pretty understandable with the globe turning, that remapping the labels or arrows is beyond my understanding graphically. But all I am asking is simply, is there a fix for this other than removing the count labels over the arrows?
I’ve read enough guesses on the web. If someone has actually found a fix, I’d love to read it.
Thanks tons
Hi, what version of CesiumJS are you using? This should not occur when using the most recent versions, but can occur in older versions.
did you solve it? it due to the labels for sure, when i remove the labels, the warning disappear
