KML labels disabled when using clustering?
**I’m loading some kml and I have many placemarks in the same location. I decided to implement the clustering feature in Cesium, but when I did all of the labels were never shown. Judging from the KML and clustering sandcastle examples, this appears to be a Cesium side-effect of clustering. **
Check the sandcastle KML and clustering examples. The clustering application doesn’t show the labels.
I need the labels to be visible when the placemarks are visible(cluster pins hidden). Is there a known workaround?
**Cesium 1.51, Windows 10, Chrome 70 **
Hey Scott,
I think this is a known bug, which I’ve gone ahead and bumped on GitHub:
https://github.com/AnalyticalGraphicsInc/cesium/issues/6087
If you end up figuring out a way to get it to work it’d definitely be awesome if you can contribute it back to CesiumJS! Otherwise, I wonder if implementing your own version of this with distance display conditions would be simpler. Although that doesn’t take into account distances between the entities.
