Hey, I would like to know about labelling on the globe using latitudes and longitude parameters.
Hi Vaisakh,
If you have Cesium up and running, I would just start with this Sandcastle example: http://cesium.agi.com/Cesium/Apps/Sandcastle/index.html?src=Labels.html
If you’re new to Cesium in general and need to get up and running first, I would check out our getting started tutorial: http://cesium.agi.com/2013/04/12/Cesium-up-and-running/
These two pages should provide you with everything you need, but if any of it is unclear to you, please let us know.
Hi Matthew
I have Cesium up and running and I started with Sandcastle example. I’m planning to plot the label using only latitude and longitude using a json file, whereas Cesium used a third parameter height. Kindly help me for the same.
If you’re using Cesium without terrain, then a height of zero will put your label on the surface. If you are using terrain, you can use the sampleTerrain function to find the heights for each of your positions.
