Limit movements area
I was curious, so I threw this together.
Go to http://cesium.agi.com/Cesium/Apps/Sandcastle/index.html?src=Cesium%20Viewer%20Widget.html and paste the below code. When you switch to 2D mode, you should have what you want. I shut inertia off because it created some unpleasant jumpiness along the edges. This isn’t perfect, and it only works for 2D, but it should get you started.
require([‘Cesium’], function(Cesium) {
“use strict”;
var viewer = new Cesium.Viewer(‘cesiumContainer’);
//Set up the max extent.
var west = Cesium.Math.toRadians(-77.0);
var south = Cesium.Math.toRadians(38.0);
var east = Cesium.Math.toRadians(-72.0);
var north = Cesium.Math.toRadians(42.0);
var maxExtent = new Cesium.Extent(west, south, east, north);
viewer.scene.getScreenSpaceCameraController().inertiaTranslate = 0;
viewer.clock.onTick.addEventListener(function() {
if (viewer.scene.mode === Cesium.SceneMode.SCENE2D) {
var topLeft = viewer.scene.getCamera().controller.pickEllipsoid(new Cesium.Cartesian2(0, 0));
var topRight = viewer.scene.getCamera().controller.pickEllipsoid(new Cesium.Cartesian2(viewer.canvas.clientWidth, 0));
var bottomLeft = viewer.scene.getCamera().controller.pickEllipsoid(new Cesium.Cartesian2(0, viewer.canvas.clientHeight));
var bottomRight = viewer.scene.getCamera().controller.pickEllipsoid(new Cesium.Cartesian2(viewer.canvas.clientWidth, viewer.canvas.clientHeight));
if (topLeft && topRight && bottomLeft && bottomRight) {
topLeft = Cesium.Ellipsoid.WGS84.cartesianToCartographic(topLeft);
topRight = Cesium.Ellipsoid.WGS84.cartesianToCartographic(topRight);
bottomLeft = Cesium.Ellipsoid.WGS84.cartesianToCartographic(bottomLeft);
bottomRight = Cesium.Ellipsoid.WGS84.cartesianToCartographic(bottomRight);
var visibleExtent = Cesium.Extent.fromCartographicArray([topLeft, topRight, bottomLeft, bottomRight]);
if (!maxExtent.contains(visibleExtent)) {
var validExtent = visibleExtent.intersectWith(maxExtent);
viewer.scene.getCamera().controller.viewExtent(validExtent, Cesium.Ellipsoid.WGS84);
} else {
viewer.scene.getCamera().controller.viewExtent(maxExtent, Cesium.Ellipsoid.WGS84);
Sandcastle.finishedLoading();
