Hey guys → Here is the asset id: 1395008
It is an uploaded glb file.
It should have lines attached to the block seen in the image below.
But the cesium tileset does not have any lines attached nor any lines elswhere (there are a few other instances) in the model.
Is there a reason for the missing lines?
Hi
Would you be able to confirm if the lines missing were represented as Lines or Triangles in the original model?
Shehzan
They are coming in as lines in the glb file (mode: 1)
I believe those may not be supported in the 3D Tiling Pipeline. We’ll open an issue to that its being tracked and fixed on the roadmap.
