Here is the viewer change
var viewer = new Cesium.Viewer(“cesiumContainer”, {
shouldAnimate: true,
terrainProvider : Cesium.createWorldTerrain()
Zoom all the way in and out …
Hi Sam,
Hi Sam,
Thank you for sharing your sandcastle demo with the community. It looks like sections of the KML are being hidden as I zoom towards the terrain.
This error might be related to multi-frustum artifacts. Thus, it may be fixed by enabling log depth. Please try setting
scene.logarithmicDepthBuffer = true;
scene.camera.frustum.near = 0.1;
scene.camera.frustum.far = 10000000000.0;
-Sam
Hi Sam.
I see the same issue. This is what I did on your sandcastle.
var viewer = new Cesium.Viewer(“cesiumContainer”,{terrainProvider : Cesium.createWorldTerrain()});
viewer.scene.logarithmicDepthBuffer = true;
viewer.scene.camera.frustum.near = 0.1;
viewer.scene.camera.frustum.far = 10000000000.0;
Let me know if this is what you were asking.
Carlo
Are you still seeing the same issue even when you update your project to include the following code?
-Sam
I have some code with the same bug. Adding those 3 lines didn’t fix it. If I find a solution I’ll post it here. It vanishes if I zoom in and generally looks strange as I pan and tilt the view. The same code works perfectly with other data in a different location!
const redLine = viewer.entities.add({
name: “Route”, polyline: {
positions: Cesium.Cartesian3.fromDegreesArray(posns),
width: 15,
material: Cesium.Color.RED,
clampToGround: true, },
Hi @elolelo,
I would recommend setting the disableDepthTestDistance property for billboards and labels in this case.
hello, sample problem , have you resolved?
